Zum Hauptinhalt wechseln
Google Pixelbook Go Battery Replacement
Was du brauchst
  1. Google Pixelbook Go Battery Replacement, Back Panel: Schritt 1, Bild 1 von 2 Google Pixelbook Go Battery Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Flip the device so that the back is facing up.
    • Peel the rubber stoppers off the top and bottom of the device.
  2. Google Pixelbook Go Battery Replacement: Schritt 2, Bild 1 von 2 Google Pixelbook Go Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove ten 3 mm screws from around the edge of the back panel using a T5 Torx screwdriver.
  3. Google Pixelbook Go Battery Replacement: Schritt 3, Bild 1 von 3 Google Pixelbook Go Battery Replacement: Schritt 3, Bild 2 von 3 Google Pixelbook Go Battery Replacement: Schritt 3, Bild 3 von 3
    • Use an iFixit opening tool to pry up the back panel cover.
    • There is an orange ribbon cable that connects the cover to the base, so don't separate the two pieces completely.
    • Remove the single 2 mm screw using a Torx T3 screwdriver.
    • Disconnect the orange cable from the base of the device.
  4. Google Pixelbook Go Battery Replacement: Schritt 4, Bild 1 von 1
    • Insert wisdom here.
  5. Google Pixelbook Go Battery Replacement, Battery: Schritt 5, Bild 1 von 1
    • If your replacement battery comes with a new cover already attached, disregard this step.
    • Use an iFixit opening tool to peel back the adhesive on the entire battery system.
    • Carefully remove battery from the base.
    • Align the new battery system with the cover and attach using adhesive or double-sided tape.
Abschluss
Caroline Gilliard
81 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 20
Letzte 30 Tage: 155
Insgesamt: 2,159
