Zum Hauptinhalt wechseln
HAMILTON C-1 Bacterial Filter Replacement (Coaxial Circuit Setup)
Medizinische Ausrüstung
Weder iFixit noch diese Reparaturanleitung werden vom Hersteller medizinischer Geräte unterstützt oder sind mit diesem verbunden.
  1. HAMILTON C-1 Bacterial Filter Replacement (Coaxial Circuit Setup), Bacterial Filter: Schritt 1, Bild 1 von 1
    • Orient Hamilton-C1 so the right side of the device is facing you.
  2. HAMILTON C-1 Bacterial Filter Replacement (Coaxial Circuit Setup): Schritt 2, Bild 1 von 1
    • Disconnect HME (heat and moisture exchanger) and flex tube
    • Bacterial filter is held within the HME.
    • Use both hands to gently pull and/or twist the flex tube and HME away from one another until fully disconnected.
    • The HME should still be connected to the overall circuit setup.
    • In reassembly, a new HME with a non-contaminated bacterial filter will be reconnected to the flex tube for this step.
  3. HAMILTON C-1 Bacterial Filter Replacement (Coaxial Circuit Setup): Schritt 3, Bild 1 von 1
    • Disconnect HME and circuit setup
    • Use both hands to gently pull and/or twist the flow sensor and HME away from one another until fully disconnected.
    • The HME (with used/contaminated bacterial filter) should now be completely disconnected from all parts.
    • In reassembly, a new HME with a non-contaminated bacterial filter will be reconnected to the flow sensor for this step.
Abschluss
Luisa Chiu
205 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S7-G11, Paton Spring 2020 Mitglied von Cal Poly, Team S7-G11, Paton Spring 2020
CPSU-PATON-S20S7G11
2 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Okay how offen should change out a carbon filter?
Bill Mcleod - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 23
Insgesamt: 767
