Zum Hauptinhalt wechseln
HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup)
Medizinische Ausrüstung
Weder iFixit noch diese Reparaturanleitung werden vom Hersteller medizinischer Geräte unterstützt oder sind mit diesem verbunden.
  1. HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup), Bacterial Filter: Schritt 1, Bild 1 von 1
    • Orient Hamilton-C1 so the right side of the device is facing you.
  2. HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup): Schritt 2, Bild 1 von 1
    • Disconnect used/contaminated INSPIRATORY bacterial filter from circuit setup
    • Gently twist and pull the used/contaminated bacterial filter from the inspiratory outlet.
    • Next, twist and pull the used/contaminated bacterial filter from the inspiratory limb.
    • The used/contaminated bacterial filter should now be removed from the inspiratory port.
    • In reassembly, a new/non-contaminated INSPIRATORY bacterial filter will be used for this step. In addition, use a twist and pushing motion instead.
  3. HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup): Schritt 3, Bild 1 von 1
    • Disconnect used/contaminated EXPIRATORY bacterial filter from circuit setup
    • Gently twist and pull the used/contaminated bacterial filter from the expiratory outlet.
    • Next, twist and pull the used/contaminated bacterial filter from the expiratory limb.
    • The used/contaminated bacterial filter should now be removed from the expiratory port.
    • In reassembly, a new/non-contaminated EXPIRATORY bacterial filter will be used for this step. In addition, use a twist and pushing motion instead.
  4. HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup): Schritt 4, Bild 1 von 1
    • Your two new bacterial filters should now be installed in their respective inspiratory and expiratory ports.
    • After completing all steps, the end result should look like this:
Abschluss
Luisa Chiu
205 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S7-G11, Paton Spring 2020 Mitglied von Cal Poly, Team S7-G11, Paton Spring 2020
CPSU-PATON-S20S7G11
2 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 366
