Einleitung
If your HMDX Chill will not play through headphones or other audio port devices, you can fix the problem by replacing the audio port. This guide will show you how to disassemble the HMDX Chill. This guide will also show you how to locate the audio port so you can replace the defective audio port.
Was du brauchst
Insert a metal spudger under the rubber base.
Pry the rubber base off.
Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
Use a Phillips #1 screwdriver to remove the four 6 mm screws that secure the motherboard to the base of the device.
Use a soldering iron to desolder the wires connecting the motherboard to the case.
Insert the spudger between the case and the wire and move the spudger upwards.
The wire behind the motherboard will now be visible. Pull this out from behind.
Use the soldering iron to desolder the wires connecting the motherboard to the base of the HMDX Chill.
Desolder the audio jack from the motherboard using a soldering iron.
