Einleitung
If your HMDX Chill is no longer charging but your charging cable is functioning properly, the solution to this problem can be found through replacing the USB Charging Port. This guide will show how to disassemble the device to locate the charging port. After the HMDX Chill is disassembled, this guide will teach you how to replace the broken charging port .
Was du brauchst
Insert a metal spudger under the rubber base.
Pry the rubber base off.
Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
Use a Phillips #1 screwdriver to remove the four 6 mm screws that secure the motherboard to the base of the device.
Use a soldering iron to desolder the wires connecting the motherboard to the case.
Insert the spudger between the case and the wire and move the spudger upwards.
The wire behind the motherboard will now be visible. Pull this out from behind.
Use the soldering iron to desolder the wires connecting the motherboard to the base of the HMDX Chill.
Using a soldering tool, desolder the charging port from the motherboard.
Ein Kommentar
I have the charging port removed. Where do I find a replacement??
