Zum Hauptinhalt wechseln
HMDX Chill Motherboard Replacement
Was du brauchst
  1. HMDX Chill Motherboard Replacement, Remove Rubber Base: Schritt 1, Bild 1 von 3 HMDX Chill Motherboard Replacement, Remove Rubber Base: Schritt 1, Bild 2 von 3 HMDX Chill Motherboard Replacement, Remove Rubber Base: Schritt 1, Bild 3 von 3
    • Insert a metal spudger under the rubber base.
    • Pry the rubber base off.
  2. HMDX Chill Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
  3. HMDX Chill Motherboard Replacement: Schritt 3, Bild 1 von 2 HMDX Chill Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Grip the base of the HMDX Chill.
    • Pull the base upwards.
  4. HMDX Chill Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 3 HMDX Chill Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 3 HMDX Chill Motherboard Replacement, Motherboard: Schritt 4, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove the four 6 mm screws that secure the motherboard to the base of the device.
  5. HMDX Chill Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Pull the motherboard away from the base gently.
    • Do not pull too hard on the motherboard. It is still attached to the base by wires.
  6. HMDX Chill Motherboard Replacement: Schritt 6, Bild 1 von 3 HMDX Chill Motherboard Replacement: Schritt 6, Bild 2 von 3 HMDX Chill Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Use a soldering iron to desolder the wires connecting the motherboard to the case.
  7. HMDX Chill Motherboard Replacement: Schritt 7, Bild 1 von 2 HMDX Chill Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Insert the spudger between the case and the wire and move the spudger upwards.
    • This will cause the case to prop open.
    • The wire behind the motherboard will now be visible. Pull this out from behind.
  8. HMDX Chill Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Use the soldering iron to desolder the wires connecting the motherboard to the base of the HMDX Chill.
Abschluss
EWU-Giguere-S16S1G1 Mitglied von EWU-Giguere-S16S1G1
Community
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 418
