Zum Hauptinhalt wechseln
HP 14-dq0051dx Touchpad Replacement
Was du brauchst
  1. HP 14-dq0051dx Touchpad Replacement, Back Case: Schritt 1, Bild 1 von 2 HP 14-dq0051dx Touchpad Replacement, Back Case: Schritt 1, Bild 2 von 2
    • Turn the laptop upside down so the backside is facing up.
    • Use a Phillips #1 screwdriver to remove eight screws from the back case.
  2. HP 14-dq0051dx Touchpad Replacement: Schritt 2, Bild 1 von 1
    • Turn the laptop over and open the screen.
    • Insert the opening tool into the seam between the bottom panel and the keyboard.
    • Run the opening tool along the entire seam to separate the bottom panel.
    • You may hear clicking as you release the taps that secure the case.
  3. HP 14-dq0051dx Touchpad Replacement: Schritt 3, Bild 1 von 1
    • Once the bottom panel is separated from the laptop, carefully close the laptop and turn it upside down.
    • Place both your hands on opposite ends of the bottom panel, and lift up and remove the panel.
  4. HP 14-dq0051dx Touchpad Replacement, Battery: Schritt 4, Bild 1 von 3 HP 14-dq0051dx Touchpad Replacement, Battery: Schritt 4, Bild 2 von 3 HP 14-dq0051dx Touchpad Replacement, Battery: Schritt 4, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove the four 2.5 mm screws that secure the battery.
    • Remove the battery from the laptop.
  5. HP 14-dq0051dx Touchpad Replacement, Touchpad: Schritt 5, Bild 1 von 3 HP 14-dq0051dx Touchpad Replacement, Touchpad: Schritt 5, Bild 2 von 3 HP 14-dq0051dx Touchpad Replacement, Touchpad: Schritt 5, Bild 3 von 3
    • Use the tip of a spudger or your fingernail to flip up the small locking flap from ZIF connector that attaches the touchpad cable to the motherboard.
    • Pull the ribbon cable out from the connector.
    • Use caution and do not yank or kink the cable, as you might damage it.
  6. HP 14-dq0051dx Touchpad Replacement: Schritt 6, Bild 1 von 3 HP 14-dq0051dx Touchpad Replacement: Schritt 6, Bild 2 von 3 HP 14-dq0051dx Touchpad Replacement: Schritt 6, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the three 2.0 mm screws from the metal plate covering the bottom of the touch pad.
    • Use an opening tool to remove the bottom plate.
  7. HP 14-dq0051dx Touchpad Replacement: Schritt 7, Bild 1 von 3 HP 14-dq0051dx Touchpad Replacement: Schritt 7, Bild 2 von 3 HP 14-dq0051dx Touchpad Replacement: Schritt 7, Bild 3 von 3
    • Lift up the flap covering to the top of the touchpad.
    • Use a Phillips #1 screwdriver to remove the three 1.5 mm screws from the top of the touchpad.
    • Use the opening tool to carefully lift up and remove the touchpad.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 19
Insgesamt: 178
