Einleitung
If your HP 14-dq0060nr is unable to properly read SD cards, use this guide to replace the card reader board.
The card reader board is used to read and write information on an SD card. A faulty card reader board may prevent the device from interacting with the SD card.
Before using this replacement guide, try using different SD cards to ensure that the problem is not with the SD card.
Before beginning, make sure to power off your device completely and disconnect from any external power source.
Was du brauchst
Flip the laptop over so the backside is facing up.
Use a spudger to remove the grips from the back case to reveal screws underneath.
Use a Phillips #1 screwdriver to remove six 6.0 mm screws and two 4.0 mm Phillips #1 screws.
Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
Pull the battery cable away from the connector in the same direction that the individual wires are running.
Remove the battery from the laptop frame.
To disconnect the cable from the card reader board, use the tip of a spudger or your fingernail to flip up the small locking flap of the ZIF connector. Then, you can safely pull the cable out.
Use a Phillips #1 screwdriver to remove the two 3.0 mm screws securing the card reader board to the chassis.
Use tweezers to carefully remove the card reader board.
