Was du brauchst
Remove the two 4 mm screws using a Phillips #0 screwdriver.
Remove the six remaining 6 mm screws located around the edges and underneath the feet using a Phillips #0 screwdriver.
Flip the laptop right-side up and slide an iFixit opening tool and/or Jimmy inside of the bottom cover seam to pry it open.
Remove the three silver screws (one 2 mm screw and two 4 mm screws) holding down the fan using a Phillips #0 screwdriver.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Unplug the fan’s power cord from the motherboard.
Remove the four gray 3 mm screws around the heat sink using a Phillips #0 screwdriver.
Remove the heat sink.
