Einleitung
This guide will teach you how to remove the HP 14-fq1025nr ports and replace them with new ones. Computer ports allow for external devices to be plugged into the computer and allow input devices like mice to be used as well as external storage devices like flash drives to be accessed by the computer. Faulty ports may result in devices not being recognized by the computer. For additional information and help for troubleshooting the ports, refer to our troubleshooting page. The ports are soldered down to the motherboard itself; therefore, to avoid damaging the motherboard, this guide will primarily go over replacing the motherboard in order to replace the ports.
WARNING: The computer uses a lithium-ion battery which contains toxic substances / flammable substances. Handle with caution.
Was du brauchst
Use a pair of tweezers to grab and pull the feet off of the cover.
Remove the two 4 mm screws using a Phillips #0 screwdriver.
Remove the six remaining 6 mm screws located around the edges and underneath the feet using a Phillips #0 screwdriver.
Flip the laptop right-side up and slide an iFixit opening tool and/or Jimmy inside of the bottom cover seam to pry it open.
Remove the four gray 3 mm screws holding down the battery using a Phillips #0 screwdriver.
Remove the three silver screws (one 2 mm screw and two 4 mm screws) holding down the fan using a Phillips #0 screwdriver.
Unplug the fan’s power cord from the motherboard.
Remove the five 3 mm gray screws from around the motherboard using a Phillips #00 screwdriver.
Unplug the wire connections.
