Zum Hauptinhalt wechseln
HP 14-fq1025nr Ports Replacement
Was du brauchst
  1. HP 14-fq1025nr Ports Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Flip the laptop upside down so the bottom cover is facing up.
  2. HP 14-fq1025nr Ports Replacement: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use a pair of tweezers to grab and pull the feet off of the cover.
  3. HP 14-fq1025nr Ports Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 4 mm screws using a Phillips #0 screwdriver.
    • Remove the six remaining 6 mm screws located around the edges and underneath the feet using a Phillips #0 screwdriver.
  4. HP 14-fq1025nr Ports Replacement: Schritt 4, Bild 1 von 1
    • Flip the laptop right-side up and slide an iFixit opening tool and/or Jimmy inside of the bottom cover seam to pry it open.
  5. HP 14-fq1025nr Ports Replacement: Schritt 5, Bild 1 von 1
    • Remove the bottom cover.
  6. HP 14-fq1025nr Ports Replacement, Battery: Schritt 6, Bild 1 von 2 HP 14-fq1025nr Ports Replacement, Battery: Schritt 6, Bild 2 von 2
    • Remove the four gray 3 mm screws holding down the battery using a Phillips #0 screwdriver.
  7. HP 14-fq1025nr Ports Replacement: Schritt 7, Bild 1 von 1
    • Remove the battery.
  8. HP 14-fq1025nr Ports Replacement, Fan: Schritt 8, Bild 1 von 1
    • Remove the three silver screws (one 2 mm screw and two 4 mm screws) holding down the fan using a Phillips #0 screwdriver.
  9. HP 14-fq1025nr Ports Replacement: Schritt 9, Bild 1 von 1
    Kaufen
    • Unplug the fan’s power cord from the motherboard.
    • Use tweezers to pull the plug out, if needed.
  10. HP 14-fq1025nr Ports Replacement: Schritt 10, Bild 1 von 1
    • Remove the fan.
  11. HP 14-fq1025nr Ports Replacement, Motherboard: Schritt 11, Bild 1 von 3 HP 14-fq1025nr Ports Replacement, Motherboard: Schritt 11, Bild 2 von 3 HP 14-fq1025nr Ports Replacement, Motherboard: Schritt 11, Bild 3 von 3
    • Remove the five 3 mm gray screws from around the motherboard using a Phillips #00 screwdriver.
  12. HP 14-fq1025nr Ports Replacement: Schritt 12, Bild 1 von 2 HP 14-fq1025nr Ports Replacement: Schritt 12, Bild 2 von 2
    Kaufen
    • Unplug the wire connections.
    • Use tweezers if needed.
  13. HP 14-fq1025nr Ports Replacement: Schritt 13, Bild 1 von 1
    • Remove the motherboard.
    • Use the iFixit opening tool to pry it out if needed.
  14. HP 14-fq1025nr Ports Replacement, Ports: Schritt 14, Bild 1 von 1
Abschluss
Alex Cutler
301 Reputation
3 Anleitungen geschrieben
Utah Tech University, Team 1-6, McMurrin Fall 2022 Mitglied von Utah Tech University, Team 1-6, McMurrin Fall 2022
UTAHTECH-MCMURRIN-F22S1G6
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 11
Insgesamt: 110
