Zum Hauptinhalt wechseln
HP 15-ay078nr Optical Drive Replacement
Was du brauchst
  1. HP 15-ay078nr Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Orient the laptop so that the underside is facing up.
    • Rotate the device so that the CD slot is in the upper left corner.
  2. HP 15-ay078nr Optical Drive Replacement: Schritt 2, Bild 1 von 2 HP 15-ay078nr Optical Drive Replacement: Schritt 2, Bild 2 von 2
    • Put your fingers on the battery latch.
  3. HP 15-ay078nr Optical Drive Replacement: Schritt 3, Bild 1 von 2 HP 15-ay078nr Optical Drive Replacement: Schritt 3, Bild 2 von 2
    • Using your fingers, push each battery latch simultaneously towards the middle.
    • This releases the battery.
    • Remove the battery from the laptop.
  4. HP 15-ay078nr Optical Drive Replacement, Back Panel: Schritt 4, Bild 1 von 2 HP 15-ay078nr Optical Drive Replacement, Back Panel: Schritt 4, Bild 2 von 2
    • Pull off the two rubber feet on the underside of the device.
    • Remove the twelve 9.5 mm screws from the underside of the device using a Phillips #2 screwdriver.
  5. HP 15-ay078nr Optical Drive Replacement: Schritt 5, Bild 1 von 1
    • Slide an opening pick around the edges between the back panel and the rest of the device to release the plastic retention clips that hold the panel in place.
  6. HP 15-ay078nr Optical Drive Replacement: Schritt 6, Bild 1 von 1
    • Lift up on the panel to remove it completely from the device.
  7. HP 15-ay078nr Optical Drive Replacement, Optical Drive: Schritt 7, Bild 1 von 1
    • Slide the optical drive outward through the cutout in the device back panel to remove it from the laptop.
Abschluss
Bryce Getchell
315 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 3-1, Sinclaire Fall 2021 Mitglied von UMass Dartmouth, Team 3-1, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G1
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 129
