Zum Hauptinhalt wechseln
HP 15-ay078nr Screen Replacement
Was du brauchst
  1. HP 15-ay078nr Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • Open the lid of the laptop.
    • Feel the top of the laptop screen to find a ridge separating the front and back of the screen bezel.
    • Using an opening pick tool, gently pry the front screen bezel apart from the rear to release the internal plastic retention clips.
    • You may see small bits of plastic come loose from the screen bezel. This is not an issue and will not hurt the reassembly process.
  2. HP 15-ay078nr Screen Replacement: Schritt 2, Bild 1 von 2 HP 15-ay078nr Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove the four 3.2 mm screws from the screen using a Phillips #2 screwdriver.
  3. HP 15-ay078nr Screen Replacement: Schritt 3, Bild 1 von 3 HP 15-ay078nr Screen Replacement: Schritt 3, Bild 2 von 3 HP 15-ay078nr Screen Replacement: Schritt 3, Bild 3 von 3
    • Gently lay the screen against the keyboard.
    • Disconnect the display cable from the rest of the laptop.
Abschluss
Power on your device to see the new screen. If the backlight is flickering, the LCD cable may have not been pushed in completely. Ensure it is fully connected.
UMass Dartmouth, Team 3-1, Sinclaire Fall 2021 Mitglied von UMass Dartmouth, Team 3-1, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G1
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 188
