Zum Hauptinhalt wechseln
HP 15-bs168cl Hard Drive Replacement
Was du brauchst
  1. HP 15-bs168cl Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 HP 15-bs168cl Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Unplug your laptop from its power adapter.
    • Turn the laptop over.
  2. HP 15-bs168cl Hard Drive Replacement: Schritt 2, Bild 1 von 2 HP 15-bs168cl Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Slide the Battery lock slider to the right until you see the “Unlocked” lock symbol.
  3. HP 15-bs168cl Hard Drive Replacement: Schritt 3, Bild 1 von 2 HP 15-bs168cl Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Slide the Battery release slider towards the battery while pulling the battery out.
  4. HP 15-bs168cl Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 2 HP 15-bs168cl Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the six 10.5 mm screws visible on the bottom of the laptop.
  5. HP 15-bs168cl Hard Drive Replacement: Schritt 5, Bild 1 von 2 HP 15-bs168cl Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Carefully peel the four rubber feet off the bottom to reveal the four hidden screws.
    • Use a Phillips #1 screwdriver to remove the four 10.5 mm screws.
  6. HP 15-bs168cl Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Remove the DVD drive by carefully sliding it out.
  7. HP 15-bs168cl Hard Drive Replacement: Schritt 7, Bild 1 von 3 HP 15-bs168cl Hard Drive Replacement: Schritt 7, Bild 2 von 3 HP 15-bs168cl Hard Drive Replacement: Schritt 7, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    • Flip the laptop over and open the screen.
    • Carefully use a flat plastic card to separate the bottom plastic shell from the main body of the computer. Slowly slide the plastic card around the computer in between the two halves of its casing.
    • Flip the computer back over and remove the bottom plastic shell.
  8. HP 15-bs168cl Hard Drive Replacement: Schritt 8, Bild 1 von 3 HP 15-bs168cl Hard Drive Replacement: Schritt 8, Bild 2 von 3 HP 15-bs168cl Hard Drive Replacement: Schritt 8, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove the two 3.4 mm screws on the sides.
    • Use a Phillips #0 screwdriver to remove the one 3.3 mm screw at the bottom of the bracket.
  9. HP 15-bs168cl Hard Drive Replacement: Schritt 9, Bild 1 von 2 HP 15-bs168cl Hard Drive Replacement: Schritt 9, Bild 2 von 2
    • Remove the metal bracket holding the hard drive in place.
    • Carefully lift up the hard drive and slide it out of its connector.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Ian Gascon
816 Reputation
4 Anleitungen geschrieben
UC Santa Barbara, Team S3-G3, Nowak Fall 2019 Mitglied von UC Santa Barbara, Team S3-G3, Nowak Fall 2019
UCSB-NOWAK-F19S3G3
3 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Thanks, I would have missed the screws under the rubber feet!
Kenneth Dalton - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 15
Insgesamt: 1,593
