Zum Hauptinhalt wechseln
HP 15-f004dx Battery Replacement
Was du brauchst
  1. HP 15-f004dx Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • After testing the battery and discovering that it needs to be replaced, you will begin by placing the computer upside-down on a flat surface.
  2. HP 15-f004dx Battery Replacement: Schritt 2, Bild 1 von 2 HP 15-f004dx Battery Replacement: Schritt 2, Bild 2 von 2
    • Locate a switch in the upper left corner with a lock symbol next to it.
    • Slide the switch to the right until you see an unlocked symbol on the opposite side.
  3. HP 15-f004dx Battery Replacement: Schritt 3, Bild 1 von 2 HP 15-f004dx Battery Replacement: Schritt 3, Bild 2 von 2
    • There is another switch on the opposite side of the computer with a battery symbol next to it.
    • Slide this switch to the left and the battery should detach from the computer.
    • To completely remove the battery, simply pull the battery away from the computer.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 311
