Zum Hauptinhalt wechseln
HP 15-f004dx Keyboard Replacement
Was du brauchst
  1. HP 15-f004dx Keyboard  Replacement, Battery: Schritt 1, Bild 1 von 1
    • After testing the battery and discovering that it needs to be replaced, you will begin by placing the computer upside-down on a flat surface.
  2. HP 15-f004dx Keyboard  Replacement: Schritt 2, Bild 1 von 2 HP 15-f004dx Keyboard  Replacement: Schritt 2, Bild 2 von 2
    • Locate a switch in the upper left corner with a lock symbol next to it.
    • Slide the switch to the right until you see an unlocked symbol on the opposite side.
  3. HP 15-f004dx Keyboard  Replacement: Schritt 3, Bild 1 von 2 HP 15-f004dx Keyboard  Replacement: Schritt 3, Bild 2 von 2
    • There is another switch on the opposite side of the computer with a battery symbol next to it.
    • Slide this switch to the left and the battery should detach from the computer.
    • To completely remove the battery, simply pull the battery away from the computer.
  4. HP 15-f004dx Keyboard  Replacement, Keyboard: Schritt 4, Bild 1 von 1
    • Use a plastic opening tool to delicately pry the keyboard from the laptop.
    • Run the opening tool along the top edge so a good portion is lifted from the laptop.
  5. HP 15-f004dx Keyboard  Replacement: Schritt 5, Bild 1 von 1
    • Once a large enough portion of the laptop is lifted up, use your hand to finish separating the keyboard from the laptop
  6. HP 15-f004dx Keyboard  Replacement: Schritt 6, Bild 1 von 1
    • Lift the laptop and expose the connector.
    • Lift the small black tab of the keyboard ZIF connector, and gently pull the ribbon cable free.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 555
