Zum Hauptinhalt wechseln
HP 15-f004dx RAM Replacement
Was du brauchst
  1. HP 15-f004dx RAM Replacement, RAM: Schritt 1, Bild 1 von 1
    • Flip laptop over to the back, so that the stickers are showing and the RAM panel is facing up.
  2. HP 15-f004dx RAM Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #0 screwdriver to unscrew the two 2mm RAM shield screws from the bottom of the laptop.
  3. HP 15-f004dx RAM Replacement: Schritt 3, Bild 1 von 3 HP 15-f004dx RAM Replacement: Schritt 3, Bild 2 von 3 HP 15-f004dx RAM Replacement: Schritt 3, Bild 3 von 3
    • Remove the RAM shield.
    • Small brackets secure the RAM. Push the brackets to the side to free the RAM.
  4. HP 15-f004dx RAM Replacement: Schritt 4, Bild 1 von 2 HP 15-f004dx RAM Replacement: Schritt 4, Bild 2 von 2
    • The RAM card should now pop up out of its slot. Remove the RAM.
    • Next, you will replace/reseat the memory modules following steps 3 and 4 in reverse. Once you have completed that, you can now power on the computer to test and see if reseating/replacing the RAM has resolved the problem.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 9
Insgesamt: 694
