Einleitung
If the device is failing to charge it may be necessary to replace the charging port. The most difficult step will be soldering the charging port, it is important to make sure you have all tools required and follow the instructions precisely.
Was du brauchst
Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
Use the plastic opening tool to push in between the front and the back of the tablet.
Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
Remove the back cover.
Push out the battery connector using the spudger.
Swing the battery connector clear of the connector socket.
Pry the connector that attaches the front and back camera with a metal spudger.
Unplug the connector with the tweezers.
Remove the tape.
Pull the orange tape with the tweezers.
Flip the ZIF connector with the spudger.
Pull the ribbon connector with the tweezers.
Desolder the four points on the charging port using the soldering iron.
Eine weitere Person hat diese Anleitung absolviert.
