Zum Hauptinhalt wechseln
HP Chromebook 11 G5 Keyboard Replacement
Was du brauchst
  1. HP Chromebook 11 G5 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Remove four large rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  2. HP Chromebook 11 G5 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Remove two smaller rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  3. HP Chromebook 11 G5 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the 4mm eleven screws using a Phillips #00 screwdriver.
  4. HP Chromebook 11 G5 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Flip the device upright and open the screen as far back as possible.
  5. HP Chromebook 11 G5 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Wedge the flat-end of a metal spudger between the base of the device and the keyboard assembly while applying downward pressure. Slide the spudger across the entirety of the gap until the two components separate.
    • There will be audible popping sounds caused by the separation of the base of the device and the keyboard assembly as you wedge them apart.
    • Do not insert the spudger into the gap deeper than necessary as it may snag on the internal components.
  6. HP Chromebook 11 G5 Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Gently lift the keyboard assembly slightly above the base of the device.
  7. HP Chromebook 11 G5 Keyboard Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the two ribbon cables connected to the motherboard by using the pointed end of a spudger to lift the plastic connector lids to allow the ribbon cables to be gently removed by hand.
  8. HP Chromebook 11 G5 Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Gently remove the keyboard assembly by hand from the base of the device.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Salma Zitoun
367 Reputation
2 Anleitungen geschrieben
York University, Team S1-G3, Woodhouse Winter 2020 Mitglied von York University, Team S1-G3, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G3
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 15
Insgesamt: 898
