Zum Hauptinhalt wechseln
HP Chromebook 14-ak041dx Wireless Card Replacement
Was du brauchst
  1. HP Chromebook 14-ak041dx Wireless Card Replacement, Keyboard: Schritt 1, Bild 1 von 2 HP Chromebook 14-ak041dx Wireless Card Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • You will need a pair of tweezers and a Phillips screwdriver.
    • Remove eight 5mm Phillips #0 screws from the back cover of the laptop.
  2. HP Chromebook 14-ak041dx Wireless Card Replacement: Schritt 2, Bild 1 von 3 HP Chromebook 14-ak041dx Wireless Card Replacement: Schritt 2, Bild 2 von 3 HP Chromebook 14-ak041dx Wireless Card Replacement: Schritt 2, Bild 3 von 3
    • Using a pair of tweezers, remove the five grey silicone covers.
    • Remove the five 5mm Phillips #0 screws beneath the grey silicone covers.
    • Place them aside where they will not be lost.
  3. HP Chromebook 14-ak041dx Wireless Card Replacement: Schritt 3, Bild 1 von 3 HP Chromebook 14-ak041dx Wireless Card Replacement: Schritt 3, Bild 2 von 3 HP Chromebook 14-ak041dx Wireless Card Replacement: Schritt 3, Bild 3 von 3
    • Carefully open your Chromebook case and gently pull the keyboard away from the back panel.
    • Place the keyboard aside. Inspect for any visual damage or marks.
  4. HP Chromebook 14-ak041dx Wireless Card Replacement, Battery: Schritt 4, Bild 1 von 2 HP Chromebook 14-ak041dx Wireless Card Replacement, Battery: Schritt 4, Bild 2 von 2
    • Remove the four 3mm Phillips #000 screws holding the battery in place.
  5. HP Chromebook 14-ak041dx Wireless Card Replacement: Schritt 5, Bild 1 von 3 HP Chromebook 14-ak041dx Wireless Card Replacement: Schritt 5, Bild 2 von 3 HP Chromebook 14-ak041dx Wireless Card Replacement: Schritt 5, Bild 3 von 3
    • Slide a spudger underneath the white strip over the battery to gently pull the strip away from the adhesive sticking to the battery.
    • Using a pair of tweezers, grip the black tape connected to the battery, and gently pull back to unplug the battery.
  6. HP Chromebook 14-ak041dx Wireless Card Replacement: Schritt 6, Bild 1 von 1
    • Carefully lift the battery out of the laptop.
  7. HP Chromebook 14-ak041dx Wireless Card Replacement, Heat Sink: Schritt 7, Bild 1 von 3 HP Chromebook 14-ak041dx Wireless Card Replacement, Heat Sink: Schritt 7, Bild 2 von 3 HP Chromebook 14-ak041dx Wireless Card Replacement, Heat Sink: Schritt 7, Bild 3 von 3
    • Remove the two 1.5mm Phillips #000 from the copper heat sink on top of the motherboard.
    • Remove the heat sink from the laptop.
  8. HP Chromebook 14-ak041dx Wireless Card Replacement, Wireless Card: Schritt 8, Bild 1 von 2 HP Chromebook 14-ak041dx Wireless Card Replacement, Wireless Card: Schritt 8, Bild 2 von 2
    • Remove the single 2.5mm Phillips #00 screw from the wireless card.
    • Gently pull the wireless card from the motherboard to remove it.
Abschluss
Kristen Gismondi
82.023 Reputation
200 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
17.198 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 159
