Einleitung
We are going to help you remove and replace a component of your HP Chromebook CB2L. The component that this guide helps you with is the Audio Port of the HP Chromebook CB2L. Please take a look at this troubleshooting page to confirm that this component needs replacement.
Was du brauchst
Flip Chromebook over so that the bottom panel is facing upward.
Use the plastic opening tool to remove the blue panel.
Unscrew the six 1.2mm screws on the metal plate using Phillips #1 screwdriver.
Lift the white panel by gently prying around the edges using the plastic opening tool.
Disconnect the black wire which connects the audio port to motherboard.
Disconnect the gold strip connecting the audio port to motherboard
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
