Zum Hauptinhalt wechseln
HP Chromebook CB2L Battery Replacement
Was du brauchst
  1. HP Chromebook CB2L Battery Replacement, Battery: Schritt 1, Bild 1 von 2 HP Chromebook CB2L Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • First flip your HP Chromebook CB2L over such that the bottom is facing upwards.
    • Next, using the plastic opening tool remove the blue panel.
  2. HP Chromebook CB2L Battery Replacement: Schritt 2, Bild 1 von 3 HP Chromebook CB2L Battery Replacement: Schritt 2, Bild 2 von 3 HP Chromebook CB2L Battery Replacement: Schritt 2, Bild 3 von 3
    • Using the Phillips #1 screwdriver, remove the six 1.2mm screws.
    • Gently pry off the white back panel using the plastic opening tool.
  3. HP Chromebook CB2L Battery Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the battery input to the motherboard using the plastic opening tool
  4. HP Chromebook CB2L Battery Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the four 1.2mm screws using the Phillips #1 screwdriver.
  5. HP Chromebook CB2L Battery Replacement: Schritt 5, Bild 1 von 1
    • Using the plastic opening tool remove the battery from the Chromebook.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S2-G6, Lacy Spring 2017 Mitglied von USF Tampa, Team S2-G6, Lacy Spring 2017
USFT-LACY-S17S2G6
3 Mitglieder
4 Anleitungen geschrieben
2 Kommentare
the step about gently prying the underside of the laptop off made me snap off two screws under the thin blue rubber strip ! i see the holes they went in in the pictures in this guide. i understand that strip was glued on and it doesn't seem necessary to put those back (since i can't unglue the strip to put those screws back in) but.. yeah. it was unexpected and i thought i'd done something wrong.
katie - Antwort
Dont forget there are two screws underneath the small blue strip.
Roderick Wells - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 1,418
