Zum Hauptinhalt wechseln
HP Chromebook CB2L Speaker Replacement
Was du brauchst
  1. HP Chromebook CB2L Speaker Replacement, Battery: Schritt 1, Bild 1 von 2 HP Chromebook CB2L Speaker Replacement, Battery: Schritt 1, Bild 2 von 2
    • First flip your HP Chromebook CB2L over such that the bottom is facing upwards.
    • Next, using the plastic opening tool remove the blue panel.
  2. HP Chromebook CB2L Speaker Replacement: Schritt 2, Bild 1 von 3 HP Chromebook CB2L Speaker Replacement: Schritt 2, Bild 2 von 3 HP Chromebook CB2L Speaker Replacement: Schritt 2, Bild 3 von 3
    • Using the Phillips #1 screwdriver, remove the six 1.2mm screws.
    • Gently pry off the white back panel using the plastic opening tool.
  3. HP Chromebook CB2L Speaker Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the battery input to the motherboard using the plastic opening tool
  4. HP Chromebook CB2L Speaker Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the four 1.2mm screws using the Phillips #1 screwdriver.
  5. HP Chromebook CB2L Speaker Replacement: Schritt 5, Bild 1 von 1
    • Using the plastic opening tool remove the battery from the Chromebook.
  6. HP Chromebook CB2L Speaker Replacement, Speaker: Schritt 6, Bild 1 von 1
    • Using the plastic opening tool lift the black tab.
    • Disconnect the blue and black strip from the motherboard.
  7. HP Chromebook CB2L Speaker Replacement: Schritt 7, Bild 1 von 1
    • Use the Phillips #1 screwdriver to remove the four 1.2mm screws circled red.
  8. HP Chromebook CB2L Speaker Replacement: Schritt 8, Bild 1 von 3 HP Chromebook CB2L Speaker Replacement: Schritt 8, Bild 2 von 3 HP Chromebook CB2L Speaker Replacement: Schritt 8, Bild 3 von 3
    • Gently pull the black wire to disconnect the audio port from the motherboard.
    • Disconnect the black wire connecting the speaker to the motherboard with caution.
  9. HP Chromebook CB2L Speaker Replacement: Schritt 9, Bild 1 von 1
    • Use the plastic opening tool to remove the speaker from back panel.
Abschluss
USF Tampa, Team S2-G6, Lacy Spring 2017 Mitglied von USF Tampa, Team S2-G6, Lacy Spring 2017
USFT-LACY-S17S2G6
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 142
