Zum Hauptinhalt wechseln
HP Chromebox J5N50UT Bottom Cover Replacement
Was du brauchst
  1. HP Chromebox J5N50UT Bottom Cover Replacement, Bottom Cover: Schritt 1, Bild 1 von 1
    • Before removing the bottom cover, ensure that your computer is powered down and ensure that all external devices are disconnected. If you are unsure whether the computer is off or in hibernation mode, turn the computer on, then shut it down through the operating system.
    • Position the device upside-down on a flat, level surface with the USB ports facing you.
  2. HP Chromebox J5N50UT Bottom Cover Replacement: Schritt 2, Bild 1 von 1
    • Using your metal spudger, lift and remove the 4 rubber “feet” from each corner.
  3. HP Chromebox J5N50UT Bottom Cover Replacement: Schritt 3, Bild 1 von 1
    • Using your Phillips head screwdriver, remove the four Phillips M2.5×4.0 screws that secure the bottom cover to the computer. In this step the usage of the magnetic mat will be helpful to keep up with the screws.
  4. HP Chromebox J5N50UT Bottom Cover Replacement: Schritt 4, Bild 1 von 1
    • Insert the flat end of your metal spudger under the bottom cover near the USB ports, then pry the bottom cover off the computer.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ashley Marvin
685 Reputation
5 Anleitungen geschrieben
Ohio State, Team S1-G3, Whitney Fall 2018 Mitglied von Ohio State, Team S1-G3, Whitney Fall 2018
OSU-WHITNEY-F18S1G3
2 Mitglieder
Ein Kommentar
Can you explain how/where the integrated VESA mount is?
Is the mounting screw holes under the rubber feet, like other chromeboxes, from other makers?
When Ze - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 627
