Zum Hauptinhalt wechseln
HP Compaq 6710b Screen Replacement
Was du brauchst
  1. HP Compaq 6710b Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off your computer! Taking out the battery while it's still on is dangerous!
    • Flip the laptop over to the back.
    • Using two hands, push on the tabs while gently taking out the battery.
  2. HP Compaq 6710b Screen Replacement, Keyboard: Schritt 2, Bild 1 von 3 HP Compaq 6710b Screen Replacement, Keyboard: Schritt 2, Bild 2 von 3 HP Compaq 6710b Screen Replacement, Keyboard: Schritt 2, Bild 3 von 3
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
  3. HP Compaq 6710b Screen Replacement: Schritt 3, Bild 1 von 1
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
  4. HP Compaq 6710b Screen Replacement: Schritt 4, Bild 1 von 2 HP Compaq 6710b Screen Replacement: Schritt 4, Bild 2 von 2
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
  5. HP Compaq 6710b Screen Replacement: Schritt 5, Bild 1 von 1
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
  6. HP Compaq 6710b Screen Replacement, Power Button Panel: Schritt 6, Bild 1 von 1
    • Put a finger under each side of the plastic lock on the ribbon cable and pull up.
  7. HP Compaq 6710b Screen Replacement: Schritt 7, Bild 1 von 3 HP Compaq 6710b Screen Replacement: Schritt 7, Bild 2 von 3 HP Compaq 6710b Screen Replacement: Schritt 7, Bild 3 von 3
    • Using a flathead screwdriver, get under each plastic hinge cover until they pop.
    • Lift the right edge of plastic strip covering the power button and gently pull it up until the whole strip comes free.
  8. HP Compaq 6710b Screen Replacement, Screen: Schritt 8, Bild 1 von 1
    • Using a flathead screwdriver, work both sides of the connector next to the fan and take it out.
  9. HP Compaq 6710b Screen Replacement: Schritt 9, Bild 1 von 1
    • Using the T9 Torx screwdriver, remove one 7mm screw on the left hinge.
    • We recommend replacing this screw shortly after removing the cable as it helps hold the hinge to the lower half of the laptop.
  10. HP Compaq 6710b Screen Replacement: Schritt 10, Bild 1 von 1
    • Using the blue plastic opening tool, pull the rubber covers off the screen screws.
  11. HP Compaq 6710b Screen Replacement: Schritt 11, Bild 1 von 1
    • Using a T9 Torx screwdriver, remove the top four 5 mm screws.
    • Remove the bottom two 6 mm screws with the same screwdriver.
  12. HP Compaq 6710b Screen Replacement: Schritt 12, Bild 1 von 3 HP Compaq 6710b Screen Replacement: Schritt 12, Bild 2 von 3 HP Compaq 6710b Screen Replacement: Schritt 12, Bild 3 von 3
    • Using a flat head screwdriver, pry the plastic panel over the screen up starting at one of the hinges.
    • Using the flathead, continue running the it under the the plastic screen edge and gently pry it off.
    • If you press the screwdriver tip down (by lifting the handle), the screen panel pops off easier.
  13. HP Compaq 6710b Screen Replacement: Schritt 13, Bild 1 von 3 HP Compaq 6710b Screen Replacement: Schritt 13, Bild 2 von 3 HP Compaq 6710b Screen Replacement: Schritt 13, Bild 3 von 3
    • Slowly pry back the of the screen.
    • It is easiest to work both sides free at the same time.
  14. HP Compaq 6710b Screen Replacement: Schritt 14, Bild 1 von 1
    • Using your fingers, take out the two connections near the hinges.
  15. HP Compaq 6710b Screen Replacement: Schritt 15, Bild 1 von 1
    • Using the T9 Torx screwdriver, unscrew the four 4mm screws.
  16. HP Compaq 6710b Screen Replacement: Schritt 16, Bild 1 von 2 HP Compaq 6710b Screen Replacement: Schritt 16, Bild 2 von 2
    • Tilt the screen up from the top to gain access to the screws on the side.
    • Go just far enough to get to the bottom screws to avoid damaging the bracket.
    • Using the PH00 screwdriver, unscrew the 2.5mm screws on the side of the screen. There should be 4 on each side.
    • You can now take out the screen.
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
Khulan Orgil
1.171 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 4-2, Maness Spring 2015 Mitglied von Cal Poly, Team 4-2, Maness Spring 2015
CPSU-MANESS-S15S4G2
4 Mitglieder
Ein Kommentar
thank you I found it very interesting
Hassan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 10
Insgesamt: 5,580
