Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 5
Using a flat head screwdriver, pry the plastic panel over the screen up starting at one of the hinges. Using the flathead, continue running the it under the the plastic screen edge and gently pry it off. If you press the screwdriver tip down (by lifting the handle), the screen panel pops off easier.
  • Using a flat head screwdriver, pry the plastic panel over the screen up starting at one of the hinges.
  • Using the flathead, continue running the it under the the plastic screen edge and gently pry it off.
  • If you press the screwdriver tip down (by lifting the handle), the screen panel pops off easier.
Hier Übersetzung einfügen
