Zum Hauptinhalt wechseln
HP EliteBook 8470p Battery Replacement
  1. HP EliteBook 8470p Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Position the computer upside down with the opening latch facing away from you and the battery facing towards you.
    • If the battery is “swollen” or the shape is irregular, stop whatever you are doing and allow the battery to slowly discharge itself before removing it from the laptop casing. Click the link to learn how to replace and dispose of a “swollen” battery, What to do with a swollen battery.
    Frag FixBot
  2. HP EliteBook 8470p Battery Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery latch positioned to the right over to the right side. Hold it there.
    Frag FixBot
  3. HP EliteBook 8470p Battery Replacement: Schritt 3, Bild 1 von 1
    • With the latch opened, pull the battery out of its socket firmly.
    • There will likely be some resistance. However, if you find it to be excessive, the latch may not be properly opened.
    Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team 5-3, Sinclaire Fall 2022 Mitglied von UMass Dartmouth, Team 5-3, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G3
5 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 58
Insgesamt: 1,846
