Zum Hauptinhalt wechseln
HP EliteBook 8470p Fan Replacement
Was du brauchst
    1. HP EliteBook 8470p Fan Replacement, Battery: Schritt 1, Bild 1 von 1
      • Position the computer upside down with the opening latch facing away from you and the battery facing towards you.
      • If the battery is “swollen” or the shape is irregular, stop whatever you are doing and allow the battery to slowly discharge itself before removing it from the laptop casing. Click the link to learn how to replace and dispose of a “swollen” battery, What to do with a swollen battery.
      Frag FixBot
      Kommentar hinzufügen
    2. HP EliteBook 8470p Fan Replacement: Schritt 2, Bild 1 von 1
      • Slide the battery latch positioned to the right over to the right side. Hold it there.
      Frag FixBot
    3. HP EliteBook 8470p Fan Replacement: Schritt 3, Bild 1 von 1
      • With the latch opened, pull the battery out of its socket firmly.
      • There will likely be some resistance. However, if you find it to be excessive, the latch may not be properly opened.
      Frag FixBot
    1. HP EliteBook 8470p Fan Replacement, Case/Service Cover: Schritt 4, Bild 1 von 1
      • With the laptop latch still facing away from you, slide the left release latch to the left.
      • Some models may have a screw installed on this latch, if so, be sure to remove it first to avoid damaging the latch.
      Frag FixBot
    2. HP EliteBook 8470p Fan Replacement: Schritt 5, Bild 1 von 2 HP EliteBook 8470p Fan Replacement: Schritt 5, Bild 2 von 2
      • Slide the door away from you, toward the opening latch.
      • Lift the door upwards away from the computer.
      Frag FixBot
    1. HP EliteBook 8470p Fan Replacement, Fan: Schritt 6, Bild 1 von 2 HP EliteBook 8470p Fan Replacement, Fan: Schritt 6, Bild 2 von 2
      • Disconnect the fan cable located directly to the right of the fan.
      • Hold the cable by the head of it and pull firmly, do not pull by the wires, as you may damage the cable.
      Frag FixBot
    2. HP EliteBook 8470p Fan Replacement: Schritt 7, Bild 1 von 1
      • Remove the 5 mm Phillips #00screws to the bottom-left of the fan.
      • Remove the captive screw positioned to the top-right of the fan with a Phillips #00 screwdriver.
      Frag FixBot
    3. HP EliteBook 8470p Fan Replacement: Schritt 8, Bild 1 von 1
      • Lift the right side of the fan and slide it out from below the edge of the case.
      • Lift up on the fan and remove.
      Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team 5-3, Sinclaire Fall 2022 Mitglied von UMass Dartmouth, Team 5-3, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G3
5 Mitglieder
35 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 35
Insgesamt: 1,457
