Zum Hauptinhalt wechseln
HP EliteBook 8470p Memory/RAM Replacement
  1. HP EliteBook 8470p Memory/RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Position the computer upside down with the opening latch facing away from you and the battery facing towards you.
    • If the battery is “swollen” or the shape is irregular, stop whatever you are doing and allow the battery to slowly discharge itself before removing it from the laptop casing. Click the link to learn how to replace and dispose of a “swollen” battery, What to do with a swollen battery.
  2. HP EliteBook 8470p Memory/RAM Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery latch positioned to the right over to the right side. Hold it there.
  3. HP EliteBook 8470p Memory/RAM Replacement: Schritt 3, Bild 1 von 1
    • With the latch opened, pull the battery out of its socket firmly.
    • There will likely be some resistance. However, if you find it to be excessive, the latch may not be properly opened.
  4. HP EliteBook 8470p Memory/RAM Replacement, Case/Service Cover: Schritt 4, Bild 1 von 1
    • With the laptop latch still facing away from you, slide the left release latch to the left.
    • Some models may have a screw installed on this latch, if so, be sure to remove it first to avoid damaging the latch.
  5. HP EliteBook 8470p Memory/RAM Replacement: Schritt 5, Bild 1 von 2 HP EliteBook 8470p Memory/RAM Replacement: Schritt 5, Bild 2 von 2
    • Slide the door away from you, toward the opening latch.
    • Lift the door upwards away from the computer.
    • CAUTION: Before removing the memory module, update to the latest BIOS. Failure to do so could result in various system problems.
  6. HP EliteBook 8470p Memory/RAM Replacement: Schritt 7, Bild 1 von 1
    • Spread the retaining tabs on either side of the memory module to release the module.
  7. HP EliteBook 8470p Memory/RAM Replacement: Schritt 8, Bild 1 von 2 HP EliteBook 8470p Memory/RAM Replacement: Schritt 8, Bild 2 von 2
    • Remove the memory module by pulling the module away from the slot at an angle.
  8. HP EliteBook 8470p Memory/RAM Replacement: Schritt 9, Bild 1 von 3 HP EliteBook 8470p Memory/RAM Replacement: Schritt 9, Bild 2 von 3 HP EliteBook 8470p Memory/RAM Replacement: Schritt 9, Bild 3 von 3
    • Note that the device does have two memory slots. The top slot houses the the expansion memory and the bottom slot houses the primary memory.
    • Repeat the previous steps if there is an expansion memory card
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team 5-3, Sinclaire Fall 2022 Mitglied von UMass Dartmouth, Team 5-3, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G3
5 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 30
Insgesamt: 1,136
