Zum Hauptinhalt wechseln
HP EliteBook 850 G3 Battery Replacement
Was du brauchst
  1. HP EliteBook 850 G3 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face up.
  2. HP EliteBook 850 G3 Battery Replacement, Unscrew the bottom: Schritt 2, Bild 1 von 2 HP EliteBook 850 G3 Battery Replacement, Unscrew the bottom: Schritt 2, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 Battery Replacement: Schritt 3, Bild 1 von 2 HP EliteBook 850 G3 Battery Replacement: Schritt 3, Bild 2 von 2
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry the back off.
  4. HP EliteBook 850 G3 Battery Replacement, Remove the battery screws: Schritt 4, Bild 1 von 2 HP EliteBook 850 G3 Battery Replacement, Remove the battery screws: Schritt 4, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove the two battery screws.
    • The two battery screws are captured screws and do not come out.
  5. HP EliteBook 850 G3 Battery Replacement, Lift the battery: Schritt 5, Bild 1 von 3 HP EliteBook 850 G3 Battery Replacement, Lift the battery: Schritt 5, Bild 2 von 3 HP EliteBook 850 G3 Battery Replacement, Lift the battery: Schritt 5, Bild 3 von 3
    • Lift and pull the flap located at the top of the battery to remove it.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S1-G1, Leahy Fall 2019 Mitglied von USF Tampa, Team S1-G1, Leahy Fall 2019
USFT-LEAHY-F19S1G1
4 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
Thank you very much for this guide.
Geoff Taylor - Antwort
When charging the charging indicator remain orange for hours and does not change.
Raymond Malken - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 28
Letzte 30 Tage: 142
Insgesamt: 9,213
