Zum Hauptinhalt wechseln
HP EliteBook 850 G3 Motherboard Replacement
Was du brauchst
  1. HP EliteBook 850 G3 Motherboard Replacement, WiFi Card: Schritt 1, Bild 1 von 1
    • Turn off your laptop before starting
    • Flip the laptop over so the model stickers face the ceiling.
  2. HP EliteBook 850 G3 Motherboard Replacement: Schritt 2, Bild 1 von 2 HP EliteBook 850 G3 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 Motherboard Replacement: Schritt 3, Bild 1 von 2 HP EliteBook 850 G3 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry back off.
  4. HP EliteBook 850 G3 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Use the Phillips #0 screwdriver to remove the 3.3mm screw on the WiFi card.
  5. HP EliteBook 850 G3 Motherboard Replacement: Schritt 5, Bild 1 von 2 HP EliteBook 850 G3 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Slide out the WiFi card.
  6. HP EliteBook 850 G3 Motherboard Replacement: Schritt 6, Bild 1 von 3 HP EliteBook 850 G3 Motherboard Replacement: Schritt 6, Bild 2 von 3 HP EliteBook 850 G3 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Disconnect the coaxial cables wires from the WiFi card.
  7. HP EliteBook 850 G3 Motherboard Replacement, Fan: Schritt 7, Bild 1 von 1
    • Gently unclip the plastic frame.
  8. HP EliteBook 850 G3 Motherboard Replacement: Schritt 8, Bild 1 von 3 HP EliteBook 850 G3 Motherboard Replacement: Schritt 8, Bild 2 von 3 HP EliteBook 850 G3 Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Use a Phillips #0 screwdriver to unscrew the four captive screws located near the fan and heatsink assembly.
  9. HP EliteBook 850 G3 Motherboard Replacement: Schritt 9, Bild 1 von 2 HP EliteBook 850 G3 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Carefully remove the connector for the fan.
  10. HP EliteBook 850 G3 Motherboard Replacement: Schritt 10, Bild 1 von 3 HP EliteBook 850 G3 Motherboard Replacement: Schritt 10, Bild 2 von 3 HP EliteBook 850 G3 Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Carefully remove the fan and heatsink assembly from the laptop.
    • Slide out RAM (not pictured).
  11. HP EliteBook 850 G3 Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Use a #00 Phillips screwdriver to remove twelve 5.7 mm screws from the motherboard.
  12. HP EliteBook 850 G3 Motherboard Replacement: Schritt 13, Bild 1 von 3 HP EliteBook 850 G3 Motherboard Replacement: Schritt 13, Bild 2 von 3 HP EliteBook 850 G3 Motherboard Replacement: Schritt 13, Bild 3 von 3
    • Remove the wire connectors.
  13. HP EliteBook 850 G3 Motherboard Replacement: Schritt 14, Bild 1 von 2 HP EliteBook 850 G3 Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Jiggle the motherboard until the ports (ie. headphone jack) come out from the sides and you can lift it up.
  14. HP EliteBook 850 G3 Motherboard Replacement: Schritt 15, Bild 1 von 3 HP EliteBook 850 G3 Motherboard Replacement: Schritt 15, Bild 2 von 3 HP EliteBook 850 G3 Motherboard Replacement: Schritt 15, Bild 3 von 3
    • Disconnect the wires underneath.
  15. HP EliteBook 850 G3 Motherboard Replacement: Schritt 16, Bild 1 von 3 HP EliteBook 850 G3 Motherboard Replacement: Schritt 16, Bild 2 von 3 HP EliteBook 850 G3 Motherboard Replacement: Schritt 16, Bild 3 von 3
    • Take out the motherboard.
Abschluss
USF Tampa, Team S1-G1, Leahy Fall 2019 Mitglied von USF Tampa, Team S1-G1, Leahy Fall 2019
USFT-LEAHY-F19S1G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 16
Letzte 30 Tage: 48
Insgesamt: 3,303
