Einleitung
If your HP EliteBook 850 G3 laptop not connecting to the internet, use this guide to replace the wifi card in your device. Wireless Internet cards, also known as Local Area Network, or LAN, cards, are one of the many types of adapter cards that add capabilities to your computer. If the wifi card is faulty your laptop will not connect with the internet. Before beginning, make sure to power off your laptop completely and disconnect from any external power source. Before using this guide, feel free to check out the troubleshooting page to see if any issues can be resolved without a replacement.
Was du brauchst
Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry back off.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Thank you, my HP Elitebook 850 G3 had a faulty WiFi module, it would only turn on for a second and turn off all the time in Windows 10. Tried everything inc latest drivers and clean W10 install. This guide made it easier than I thought. Replaced WiFi module with a new ordered spare and it works perfectly now.
