Zum Hauptinhalt wechseln
HP EliteBook 8560w CD/DVD ROM Replacement
Was du brauchst
  1. HP EliteBook 8560w CD/DVD ROM Replacement, Battery: Schritt 1, Bild 1 von 2 HP EliteBook 8560w CD/DVD ROM Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w CD/DVD ROM Replacement: Schritt 2, Bild 1 von 1
    • Pull the battery out.
  3. HP EliteBook 8560w CD/DVD ROM Replacement, Back Panel: Schritt 3, Bild 1 von 2 HP EliteBook 8560w CD/DVD ROM Replacement, Back Panel: Schritt 3, Bild 2 von 2
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w CD/DVD ROM Replacement: Schritt 4, Bild 1 von 1
    • Slide the panel towards you and lift it up to open and access the back of the computer.
  5. HP EliteBook 8560w CD/DVD ROM Replacement, CD/DVD ROM: Schritt 5, Bild 1 von 2 HP EliteBook 8560w CD/DVD ROM Replacement, CD/DVD ROM: Schritt 5, Bild 2 von 2
    • Unscrew one M2.5x8mm screw using a Phillips #0 screwdriver.
    • The screw does not have to come out completely.
  6. HP EliteBook 8560w CD/DVD ROM Replacement: Schritt 6, Bild 1 von 3 HP EliteBook 8560w CD/DVD ROM Replacement: Schritt 6, Bild 2 von 3 HP EliteBook 8560w CD/DVD ROM Replacement: Schritt 6, Bild 3 von 3
    • Push the metal tip to the left with a screwdriver.
  7. HP EliteBook 8560w CD/DVD ROM Replacement: Schritt 7, Bild 1 von 2 HP EliteBook 8560w CD/DVD ROM Replacement: Schritt 7, Bild 2 von 2
    • Pull out the CD/DVD ROM with your hand.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 606
