Zum Hauptinhalt wechseln
HP EliteBook x360 830 G7 Solid State Drive Replacement
Was du brauchst
  1. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the backplate: Schritt 1, Bild 1 von 2 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the backplate: Schritt 1, Bild 2 von 2
    • Turn the computer over so the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the metal shield covering the SSD: Schritt 2, Bild 1 von 1
    • Lift the metal shielding off of the solid state drive.
  3. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: Schritt 3, Bild 1 von 3 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: Schritt 3, Bild 2 von 3 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: Schritt 3, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the 4 mm screw that secures the SSD.
  4. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the SSD: Schritt 4, Bild 1 von 1
    • Gently pull the SSD free from the M.2 socket.
Abschluss
Emily Kaplan
217 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 38
Insgesamt: 1,061
