Einleitung
To make sure that replacement of the audio jack is necessary follow these troubleshooting steps before using this guide.
Was du brauchst
Using a Phillips #00 screwdriver, remove the two Phillips PM 1.4×3.2mm screws located next to the charging port.
Place the suction cup on the lower right corner of the tablet display glass, making sure to place the suction cup inside the edges of the border of the display glass.
Insert a plastic pick in between the display and the tablet case. Then use a plastic removal tool to separate the display further.
Pull on the suction cup while using the prying tool to separate the display from the tablet.
Release the zero insertion force (ZIF) connector to which the TouchScreen cable is attached, and then disconnect the TouchScreen cable from the system board.
Release the ZIF connector to which the display cable is attached, and then disconnect the display cable from the system board.
Disconnect audio jack board cable from the motherboard.
Remove the two Phillips PM 1.3x2.0mm screws that secure the audio jack board from the housing.
Remove the audio jack board.
Eine weitere Person hat diese Anleitung absolviert.
