Einleitung
Use this guide to replace the speakers in your HP ElitePad 900.
Was du brauchst
Unscrew the two 2.8mm Phillips #000 screws near the power connector.
Gently use tweezers to disconnect the indicator wire.
Slightly lift the green PCB to slide out the right speaker.
Replace the speakers.
Fast fertig!
Abschluss
