Zum Hauptinhalt wechseln
HP Envy x360 15m-bp111dx Cooling Fan Replacement
Was du brauchst
  1. HP Envy x360 15m-bp111dx Cooling Fan Replacement, Back Panel: Schritt 1, Bild 1 von 2 HP Envy x360 15m-bp111dx Cooling Fan Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Cooling Fan Replacement: Schritt 2, Bild 1 von 3 HP Envy x360 15m-bp111dx Cooling Fan Replacement: Schritt 2, Bild 2 von 3 HP Envy x360 15m-bp111dx Cooling Fan Replacement: Schritt 2, Bild 3 von 3
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Cooling Fan Replacement, Cooling Fan: Schritt 3, Bild 1 von 2 HP Envy x360 15m-bp111dx Cooling Fan Replacement, Cooling Fan: Schritt 3, Bild 2 von 2
    • Remove the three 4 mm fan screws using a Phillips screwdriver.
  4. HP Envy x360 15m-bp111dx Cooling Fan Replacement: Schritt 4, Bild 1 von 2 HP Envy x360 15m-bp111dx Cooling Fan Replacement: Schritt 4, Bild 2 von 2
    • Loosen the screws on the heatsink using the Phillips screwdriver.
    • Do not force the screws to come out of the heatsink; they are meant to stay in place.
  5. HP Envy x360 15m-bp111dx Cooling Fan Replacement: Schritt 5, Bild 1 von 1
    • Remove the tape from the heat sink by pulling upwards.
  6. HP Envy x360 15m-bp111dx Cooling Fan Replacement: Schritt 6, Bild 1 von 2 HP Envy x360 15m-bp111dx Cooling Fan Replacement: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Halberd Spudger
    $2.99
    • Using the halberd spudger, remove the sliding connector directly beside the fan.
  7. HP Envy x360 15m-bp111dx Cooling Fan Replacement: Schritt 7, Bild 1 von 3 HP Envy x360 15m-bp111dx Cooling Fan Replacement: Schritt 7, Bild 2 von 3 HP Envy x360 15m-bp111dx Cooling Fan Replacement: Schritt 7, Bild 3 von 3
    • Lift the fan assembly from the computer to remove it.
  8. HP Envy x360 15m-bp111dx Cooling Fan Replacement: Schritt 8, Bild 1 von 1
    • Replace the thermal paste on the processor using the following guide.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Eli Porter
145 Reputation
1 Anleitung geschrieben
Clemson, Team 2-2, Hunter Spring 2022 Mitglied von Clemson, Team 2-2, Hunter Spring 2022
CLEM-HUNTER-S22S2G2
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 393
