Einleitung
This replacement guide is for the memory (RAM) of the HP Envy x360 m6-w103dx. All you need to complete this guide is a plastic opening tool, a #0 Phillips screwdriver, and an anti-static wrist strap.
If you suspect there are issues with the memory, please refer to the troubleshooting guides here.
Wear the anti-static wrist strap and attach it to a metal surface to avoid damaging electrical components.
Internal components of the laptop can be hot from use. Be sure to let the laptop cool down before beginning the replacement.
Was du brauchst
Unscrew the twelve 6 mm screws from the bottom of the laptop using a Phillips #0 screwdriver.
Open the laptop carefully, with the keyboard face up.
Pry around the outside of the keyboard with the plastic opening tool until the keyboard can be lifted slightly.
Lift the keyboard until you can see the cables connected to the motherboard.
Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
Detach the keyboard.
Disconnect the pin head battery connection to remove power from the motherboard.
Unscrew the five 4mm screws holding the motherboard in place using a #0 Phillips screwdriver.
Remove the five flat ribbon cables by gently lifting the head of the cable up and back.
Remove the two remaining multicolored ribbon cables by pulling the white plastic head backwards.
Lift the motherboard up from the left side at a shallow angle.
Gently pull the motherboard to the left and gently wiggle it side to side until the ports on the right side of the board detach from the case.
Carefully lay the motherboard on a flat surface with the metal plate facing up.
Remove the metal plate from the eight surrounding inserts.
Move the two locking tabs on either side of the RAM stick away from each other.
The RAM should clear the tabs and spring up to rest at an angle to the motherboard.
Gently pull the memory stick away from the memory slot with respect to the angle at which it rests.
3 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Great tutorial! The only things that weren't mentioned are the fact that you have to detach the little metal wires from the Wi-Fi card in the top-right of the motherboard, and you also have to take out the audio jack if you want to lay the motherboard upside down. Otherwise, this was exactly what I was looking for. Thanks!
