Zum Hauptinhalt wechseln
HP G71t-400 LCD Screen Replacement
Was du brauchst
  1. HP G71t-400 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 3 HP G71t-400 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 2 von 3 HP G71t-400 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 3 von 3
    • Lay the laptop down so the bottom is facing up.
    • Push the slide button, circled in photo 1, to release the battery.
    • Action in picture 2 shows the direction and release.
    • Tilt the battery back in the direction it popped up in and remove the battery.
    • This ensures there is no power in the system that could potentially short out any components.
  2. HP G71t-400 LCD Screen Replacement: Schritt 2, Bild 1 von 3 HP G71t-400 LCD Screen Replacement: Schritt 2, Bild 2 von 3 HP G71t-400 LCD Screen Replacement: Schritt 2, Bild 3 von 3
    • Remove the stickers covering two screws on both sides just below the screen.
    • Unscrew the two screws.
    • Using the plastic opening tool to split the screen from the bezel or face of the device.
    • Disconnect the chord attaching the screen to the monitor.
    • The LCD screen is now detached from the device and ready for replacement.
Abschluss
UMass Dartmouth, Team S1-G5, Simcock Spring 2019 Mitglied von UMass Dartmouth, Team S1-G5, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G5
2 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 121
