Zum Hauptinhalt wechseln
HP LaserJet P1102w Left Side Panel Replacement
Was du brauchst
  1. HP LaserJet P1102w Left Side Panel Replacement, Left Side Panel: Schritt 1, Bild 1 von 3 HP LaserJet P1102w Left Side Panel Replacement, Left Side Panel: Schritt 1, Bild 2 von 3 HP LaserJet P1102w Left Side Panel Replacement, Left Side Panel: Schritt 1, Bild 3 von 3
    • Flip printer on it's back. Using the plastic spudger, pry off front panel. There will be two main points to focus as shown.
    • Pry carefully to not break any plastic.
  2. HP LaserJet P1102w Left Side Panel Replacement: Schritt 2, Bild 1 von 2 HP LaserJet P1102w Left Side Panel Replacement: Schritt 2, Bild 2 von 2
    • Now that the pry points are free lift up the front panel.
  3. HP LaserJet P1102w Left Side Panel Replacement: Schritt 3, Bild 1 von 2 HP LaserJet P1102w Left Side Panel Replacement: Schritt 3, Bild 2 von 2
    • Unscrew the #1 Phillips screw 6mm on the back of the printer.
  4. HP LaserJet P1102w Left Side Panel Replacement: Schritt 4, Bild 1 von 3 HP LaserJet P1102w Left Side Panel Replacement: Schritt 4, Bild 2 von 3 HP LaserJet P1102w Left Side Panel Replacement: Schritt 4, Bild 3 von 3
    • Using the plastic spudger, remove the button housing from the top left of printer.
  5. HP LaserJet P1102w Left Side Panel Replacement: Schritt 5, Bild 1 von 2 HP LaserJet P1102w Left Side Panel Replacement: Schritt 5, Bild 2 von 2
    • Once the housing is removed, remove the three buttons.
  6. HP LaserJet P1102w Left Side Panel Replacement: Schritt 6, Bild 1 von 3 HP LaserJet P1102w Left Side Panel Replacement: Schritt 6, Bild 2 von 3 HP LaserJet P1102w Left Side Panel Replacement: Schritt 6, Bild 3 von 3
    • Use the plastic spudger to remove the side panel. There are three main prying points as shown.
  7. HP LaserJet P1102w Left Side Panel Replacement: Schritt 7, Bild 1 von 2 HP LaserJet P1102w Left Side Panel Replacement: Schritt 7, Bild 2 von 2
    • With all pry points free, remove the side panel.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Jerome Etten
730 Reputation
4 Anleitungen geschrieben
UW Stout, Team S6-G4, Ogden Fall 2018 Mitglied von UW Stout, Team S6-G4, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G4
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
How to replace the HP 2055 motherboard
Wale - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 61
Insgesamt: 1,859
