Einleitung
The HP Media Center 876x can utilize its TV tuner card to receive television service, enhancing its versatility.
Should you encounter difficulty receiving adequate service, consider replacing the TV tuner card.
A TV tuner card functions as a television tuner, enabling computers to receive television signals. Additionally, many TV tuners serve as video capture cards, enabling the recording of television programs onto a hard disk similar to a digital video recorder (DVR).
Refer to the HP Media Center 876x Troubleshooting Guide if you come across any other issues.
Was du brauchst
Place the tower on its side.
Slide the side panel horizontally to detach, and pull upward to remove.
Identify the TV tuner card (distal from the cooling fan, in the lower-left corner of the tower).
Using a #0 Phillips head screwdriver, remove the one (6 mm) screw fastening the TV tuner card into its slot.
Eine weitere Person hat diese Anleitung absolviert.
