Zum Hauptinhalt wechseln
Einleitung
Replace your defective keyboard and restore the ease of being able to use your device. This guide provides a detail explanation of how to replace your device's keyboard. Before you begin, make sure you have adequately troubleshooted your broken keyboard using this Troubleshooting Page. In addition, make sure you have read through all the steps required and understand what you will be doing. Use caution when replacing the the keyboard, some of the parts have sharp edges and could be harmful. If you don't understand or feel comfortable completing any of the steps, find someone with more experience to assist you with this guide.
  1. Remove the two rubber feet closest to the black hinge.
    • Remove the two rubber feet closest to the black hinge.
  2. Remove two 6.0 mm Philips #00 screws from the back casing. Remove four 5.0 mm Philips #00 screws from the back casing.
    • Remove two 6.0 mm Philips #00 screws from the back casing.
    • Remove four 5.0 mm Philips #00 screws from the back casing.
  3. On the silver metal brace, remove the four 6.0 mm Phillips #00 screws.
    • On the silver metal brace, remove the four 6.0 mm Phillips #00 screws.
  4. Lift the metal brace and remove it from the device.
    • Lift the metal brace and remove it from the device.
  5. Laptop-Akkus
    Wenig Aufwand, große Wirkung.
    Jetzt kaufen
    Laptop-Akkus
    Jetzt kaufen
  6. Unflip the lock on the wire tape and lift that end of the tape away. Do the same for the small white piece of tape on the circuit board.
    • Unflip the lock on the wire tape and lift that end of the tape away.
    • Do the same for the small white piece of tape on the circuit board.
  7. Remove the eight 6.0 mm Philips #00 screws from the two silver holds. Remove the eight 6.0 mm Philips #00 screws from the two silver holds.
    • Remove the eight 6.0 mm Philips #00 screws from the two silver holds.
  8. Remove five 5.0 mm Philips #00 screws from the green circuit boards.
    • Remove five 5.0 mm Philips #00 screws from the green circuit boards.
  9. Lift the white pieces up. Once lifted, peel the black film away to reveal a metal plate with many black glue pieces. Once lifted, peel the black film away to reveal a metal plate with many black glue pieces.
    • Lift the white pieces up.
    • Once lifted, peel the black film away to reveal a metal plate with many black glue pieces.
  10. Using the spudger, pry each glue piece off of the metal brace. All glue pieces must be removed.
    • Using the spudger, pry each glue piece off of the metal brace. All glue pieces must be removed.
    • Use caution, the pieces may fly when they are forced out.
  11. Remove the metal plate to reveal the keyboard.
    • Remove the metal plate to reveal the keyboard.
  12. Remove the keyboard from the device. Remove the keyboard from the device.
    • Remove the keyboard from the device.
Abschluss
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 102
