Zum Hauptinhalt wechseln
HP Pavilion 15-ay041wm Keyboard Replacement
Was du brauchst
  1. HP Pavilion 15-ay041wm Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 HP Pavilion 15-ay041wm Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Place the laptop upside down.
  2. HP Pavilion 15-ay041wm Keyboard Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 15-ay041wm Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Find the battery lock latch on the top left corner.
    • Slide the latch to the right position.
  3. HP Pavilion 15-ay041wm Keyboard Replacement: Schritt 3, Bild 1 von 3 HP Pavilion 15-ay041wm Keyboard Replacement: Schritt 3, Bild 2 von 3 HP Pavilion 15-ay041wm Keyboard Replacement: Schritt 3, Bild 3 von 3
    • Find the battery release latch on the top right corner.
    • Slide and hold the latch towards the left to cover the battery icon.
    • Carefully slide the battery outwards.
  4. HP Pavilion 15-ay041wm Keyboard Replacement, Disc Drive: Schritt 4, Bild 1 von 1
    • Turn the laptop upside down with the base of the laptop facing you.
    • Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
    • Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
  5. HP Pavilion 15-ay041wm Keyboard Replacement: Schritt 5, Bild 1 von 3 HP Pavilion 15-ay041wm Keyboard Replacement: Schritt 5, Bild 2 von 3 HP Pavilion 15-ay041wm Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Press the eject button.
    • Hold and carefully slide the disc drive out of the laptop.
  6. HP Pavilion 15-ay041wm Keyboard Replacement, Keyboard: Schritt 6, Bild 1 von 3 HP Pavilion 15-ay041wm Keyboard Replacement, Keyboard: Schritt 6, Bild 2 von 3 HP Pavilion 15-ay041wm Keyboard Replacement, Keyboard: Schritt 6, Bild 3 von 3
    • Using the Jimmy, create a separation between the keyboard and bottom panel.
    • Slide around the body of the panel until the separation is big enough for you to use your fingers.
    • Separate the keyboard and bottom panel.
Abschluss
iFixit Mitglied von iFixit
Staff
123 Mitglieder
25.591 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 18
Letzte 30 Tage: 39
Insgesamt: 1,088
