Zum Hauptinhalt wechseln
HP Pavilion 15-ba003ds Disc Drive Removal
Was du brauchst
  1. HP Pavilion 15-ba003ds Disc Drive Removal, Battery: Schritt 1, Bild 1 von 2 HP Pavilion 15-ba003ds Disc Drive Removal, Battery: Schritt 1, Bild 2 von 2
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Disc Drive Removal, Disc Drive: Schritt 2, Bild 1 von 1
    • Remove the two rubber feet next to the battery.
  3. HP Pavilion 15-ba003ds Disc Drive Removal: Schritt 3, Bild 1 von 2 HP Pavilion 15-ba003ds Disc Drive Removal: Schritt 3, Bild 2 von 2
    • There are twelve 8mm screws in total that need to be unscrewed
    • Using a Phillips #00 screwdriver, unscrew them all including the two screws found underneath the rubber feet.
  4. HP Pavilion 15-ba003ds Disc Drive Removal: Schritt 4, Bild 1 von 2 HP Pavilion 15-ba003ds Disc Drive Removal: Schritt 4, Bild 2 von 2
    • Once all twelve screws are removed the disc drive can now be gently pulled out by hand.
Abschluss
Kristen Gismondi
92.414 Reputation
241 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
118 Mitglieder
19.540 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 48
Insgesamt: 175
