Was du brauchst
Unplug the AC adapter from the corresponding socket in the laptop.
Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
Carefully slide the battery out of the laptop frame and place it somewhere safe.
Remove twelve 8mm Phillips #00 screws including two underneath the rubber feet.
Fast fertig!
Abschluss
