Zum Hauptinhalt wechseln
HP Pavilion 15-cd040wm Back Cover Disassembly
Was du brauchst
  1. HP Pavilion 15-cd040wm Back Cover Disassembly, HP Pavilion 15-cd040wm Back Cover Disassembly: Schritt 1, Bild 1 von 2 HP Pavilion 15-cd040wm Back Cover Disassembly, HP Pavilion 15-cd040wm Back Cover Disassembly: Schritt 1, Bild 2 von 2
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm Back Cover Disassembly: Schritt 2, Bild 1 von 2 HP Pavilion 15-cd040wm Back Cover Disassembly: Schritt 2, Bild 2 von 2
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm Back Cover Disassembly: Schritt 3, Bild 1 von 3 HP Pavilion 15-cd040wm Back Cover Disassembly: Schritt 3, Bild 2 von 3 HP Pavilion 15-cd040wm Back Cover Disassembly: Schritt 3, Bild 3 von 3
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Joe Krawczyk
397 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S1-G1, Botvin Fall 2019 Mitglied von UMass Dartmouth, Team S1-G1, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G1
4 Mitglieder
8 Anleitungen geschrieben
3 Kommentare
It's not listed in here, but to remove the cd tray, just pull it straight out. The whole drive has a connector at the back.
Gage Cook - Antwort
I’m trying to remove my backing and it seems to have a lip that goes over the edge, so I’m having a hard time getting it apart. Any suggestions?
Laura Green - Antwort
Is this the same process for the HP Pavilion 15-cc055od? Do I pull out the disk drive as well? How would I remove the hard drive?
Baconface Smith - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 26
Letzte 30 Tage: 128
Insgesamt: 9,542
