Zum Hauptinhalt wechseln
HP Pavilion 15-cd040wm CD Drive Replacement
Was du brauchst
  1. HP Pavilion 15-cd040wm CD Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: Schritt 1, Bild 1 von 2 HP Pavilion 15-cd040wm CD Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: Schritt 1, Bild 2 von 2
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm CD Drive Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 15-cd040wm CD Drive Replacement: Schritt 2, Bild 2 von 2
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm CD Drive Replacement: Schritt 3, Bild 1 von 3 HP Pavilion 15-cd040wm CD Drive Replacement: Schritt 3, Bild 2 von 3 HP Pavilion 15-cd040wm CD Drive Replacement: Schritt 3, Bild 3 von 3
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
  4. HP Pavilion 15-cd040wm CD Drive Replacement, Battery: Schritt 4, Bild 1 von 2 HP Pavilion 15-cd040wm CD Drive Replacement, Battery: Schritt 4, Bild 2 von 2
    • 2x 5mm Philips screws
    • 2x 3mm Philips screws
  5. HP Pavilion 15-cd040wm CD Drive Replacement: Schritt 5, Bild 1 von 2 HP Pavilion 15-cd040wm CD Drive Replacement: Schritt 5, Bild 2 von 2
    • Gently pull up on the battery and tilt it away from the rest of the laptop chassis.
    • Pull out the battery at an angle and lift it out of the laptop.
  6. HP Pavilion 15-cd040wm CD Drive Replacement, CD Drive: Schritt 6, Bild 1 von 2 HP Pavilion 15-cd040wm CD Drive Replacement, CD Drive: Schritt 6, Bild 2 von 2
    • Slide the CD drive out the side of the laptop.
Abschluss
Brian Cornet
316 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S1-G1, Botvin Fall 2019 Mitglied von UMass Dartmouth, Team S1-G1, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G1
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 483
