Zum Hauptinhalt wechseln
HP Pavilion dv4000 Heat Sink Replacement
Was du brauchst
  1. HP Pavilion dv4000 Heat Sink Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 Heat Sink Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 Heat Sink Replacement: Schritt 3, Bild 1 von 1
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 Heat Sink Replacement, Heat Sink: Schritt 4, Bild 1 von 1
    • Position laptop with heat sink compartment facing you.
    • Locate the one 2x5 mm Torx screw.
  5. HP Pavilion dv4000 Heat Sink Replacement: Schritt 5, Bild 1 von 1
    • Remove the one 2x5 mm Torx screw securing the thermal cover with a #6 Torx screwdriver.
  6. HP Pavilion dv4000 Heat Sink Replacement: Schritt 6, Bild 1 von 2 HP Pavilion dv4000 Heat Sink Replacement: Schritt 6, Bild 2 von 2
    • Lift thermal cover to reveal heat sink.
    • Remove and set aside thermal cover.
  7. HP Pavilion dv4000 Heat Sink Replacement: Schritt 7, Bild 1 von 2 HP Pavilion dv4000 Heat Sink Replacement: Schritt 7, Bild 2 von 2
    • Locate the four screws on each corner of heat sink.
    • Unscrew the four 2x12 mm screws with a #00 Phillips screwdriver.
  8. HP Pavilion dv4000 Heat Sink Replacement: Schritt 8, Bild 1 von 2 HP Pavilion dv4000 Heat Sink Replacement: Schritt 8, Bild 2 von 2
    • Grab sides of heat sink and carefully lift from compartment.
    • Due to adhesive bonding of heat sink to base, wiggling it side to side before lifting might help removal process.
  9. HP Pavilion dv4000 Heat Sink Replacement: Schritt 9, Bild 1 von 1
    • To reapply thermal paste, check out iFixit's guide here.
Abschluss
UMass Dartmouth, Team 4-2, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 4-2, Catania Fall 2016
UMASSD-CATANIA-F16S4G2
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 18
Insgesamt: 752
