Zum Hauptinhalt wechseln
HP Pavilion dv6-1245dx RAM Replacement
Was du brauchst
  1. HP Pavilion dv6-1245dx RAM Replacement, RAM: Schritt 1, Bild 1 von 1
    • Shut down the computer and unplug it from the outlet.
    • All screws removed in this guide will require a Phillips #00 screwdriver.
  2. HP Pavilion dv6-1245dx RAM Replacement: Schritt 2, Bild 1 von 1
    • Turn the computer upside down.
  3. HP Pavilion dv6-1245dx RAM Replacement: Schritt 3, Bild 1 von 1
    • Loosen the three screws from the memory module compartment cover
    • Screws will not come all the way out.
  4. HP Pavilion dv6-1245dx RAM Replacement: Schritt 4, Bild 1 von 1
    • Remove the memory module compartment cover.
  5. HP Pavilion dv6-1245dx RAM Replacement: Schritt 5, Bild 1 von 3 HP Pavilion dv6-1245dx RAM Replacement: Schritt 5, Bild 2 von 3 HP Pavilion dv6-1245dx RAM Replacement: Schritt 5, Bild 3 von 3
    • Remove the first memory module by spreading apart the two silver retaining tabs, using your thumb and index finger.
    • Pull and lift the green memory module upward at a 45-degree angle, and then pull the memory module out of the computer.
    • If you are replacing both memory cards, repeat this step with the bottom memory card.
  6. HP Pavilion dv6-1245dx RAM Replacement: Schritt 6, Bild 1 von 1
    • To replace the memory card, insert the card at a 45-degree angle, then push into slot.
    • Push down gently so the silver retaining tabs click back into place.
    • If you are replacing both memory cards, replace the bottom card (closest to the system board) first.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Jaime
583 Reputation
1 Anleitung geschrieben
New Mexico State, Team 1-3, Sheppard Spring 2014 Mitglied von New Mexico State, Team 1-3, Sheppard Spring 2014
NMSU-SHEPPARD-S14S1G3
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 2,443
