Zum Hauptinhalt wechseln
HP Pavilion x360 11-p110nr Battery Replacement
Was du brauchst
  1. HP Pavilion x360 11-p110nr Battery Replacement, Battery: Schritt 1, Bild 1 von 2 HP Pavilion x360 11-p110nr Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • First, unplug the power cord from the power outlet and disconnect the charger.
    • Flip over the laptop.
    • Unscrew the back cover using the Phillips #0 screwdriver.
    • Deattach the cover carefully and do not remove the cover completely as there is a safety plastic that needs to be removed first.
    • Remove the blue safety plastic in an orthogonal motion from where it is inserted carefully.
  2. HP Pavilion x360 11-p110nr Battery Replacement: Schritt 2, Bild 1 von 2 HP Pavilion x360 11-p110nr Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove the five 1 mm screws connecting the battery to the base of the computer using a Phillips #0 screwdriver.
  3. HP Pavilion x360 11-p110nr Battery Replacement: Schritt 3, Bild 1 von 1
    • Carefully disconnect the three connectors by pulling them away from the slot.
    • If they seem hard to pull, try to wiggle them loose to making it easier to pull.
    • Pull out the battery after everything is disconnected.
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 43
Insgesamt: 949
